Bumpyroad
Oct 19, 2017Explorer
Goldencrazy wrote:
Why would the check valve matter with the bypass. Isn’t it more likely that the bypass is not closing thereby allowing antifreeze to flow into the water heater.
with the bypass open and entry into heater closed the solution will go thru the bypass and can enter the wh from the exit pipe.
bumpy
