wa8yxm
Aug 07, 2018Explorer III
Sounds like you may have the atwood (re-erad my post)
If you do you can cut away a tiny bit of insulation and remove the black box in the back side (the plumbing side) and follow the wires.
NOTE... W3 are assuming there IS an electric element.
Aome "Gas only" have a added on "hott Rodd" device. It will be screwed into the drain port on the outside. again look for the wires.
38,776 PostsLatest Activity: May 15, 2026
