subtrollExplorerDec 20, 2013Water Heater, How long do they last?The Atwood hot water heater in our 2004 National Coach no longer heats with the electrical element. The propane system heats the water fine. Access to replace the heater element will require first rem...Show More
newman_fulltimeExplorer IIDec 20, 2013Might be easier to. Pull it out and fix it but no Ned to replace if it is not speaking
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater doesn't last!
