subtrollExplorerDec 20, 2013Water Heater, How long do they last?The Atwood hot water heater in our 2004 National Coach no longer heats with the electrical element. The propane system heats the water fine. Access to replace the heater element will require first rem...Show More
ScottGNomadDec 20, 2013No, it will last many years more. Generally the only reason the electric heating part fails is because it was turned on dry.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater doesn't last!
