Old-Biscuit
Dec 20, 2013Explorer III
Ramair wrote:
One other think that you could look at is the t-stat that controls the element, I have had to replace mine once, there should be 2, one for the electric side and the other is for the propane side, should be under the black cover. Hope this helps..
Atwood uses one set of t-stats for BOTH electric & gas operation.
Suburban uses two sets-----one 120V AC set for electric and one 12V DC set for gas.
JimM68 wrote:
I'm thinking you may be incorret about access to the electric elements and control.
In my experience, all of this is accessable through the outside access door.
In most, the electric element is more or less an addon, and easily accessable through the outside panel.
Atwood t-stats are in outside compartment but electric element is accessed from the backside of tank (inside rig)
Suburban t-stats and electric element are accessed in outside compartment.
Provided they are dual heat water heaters.
Aftermarket heating rods are installed via drain holes....a whole different set-up with different ideas/opinions on their use.
OP........
Electric heating quit.
Check AC circuit breaker....turn it fully off and then back on to reset if it has tripped.
Your year/model also uses a 12V DC power (to ON/Off switch and then to a relay to allow 120V AC power to element)
Access to relay and element are on backside of WH tank under a protective cover.
Element is cheap and easy to replace once you gain access.
No need to replace WH. (You'd have to access the backside to disconnect plumbing, wiring etc in order to replace a perfectly good WH----$$$$$/PITA)
Just replace the element---1400W (Atwood #92249) $18
38,769 PostsLatest Activity: Dec 31, 2014
