woodgeezer
May 05, 2013Explorer
Certainly you can repair only the damaged portion. Sounds like you have some undercariage damage from the blowout, so it will need to be looked at anyway. By the way, are you sure it's your water heater? Could you have damaged the plumbing near the water heater? I'd look at that first, remember the WH is a pretty substantial metal container, the pipes are plastic.
38,769 PostsLatest Activity: Jul 09, 2020
