jthalbert
Jun 06, 2013Explorer
I wanted to follow up in this thread since you guys had already provided a lot of info here. It turns out that it wasn't the tank as suggested but one of the lines cracking around the end that was flared to meet the fitting on the tank.
The repair was easy enough, but now when I fill the system I can't get any water flow. This is on both the hot & cold faucets both in the kitchen & the bathroom. The pump does come on, and it does fill the hot water tank, so it seems to be working, but after its filled I get no water coming out elsewhere.
I think I've done everything correctly when filling the freshwater tanks & hot water heater - pressure release valve on hw tank is set open when filling, water pump is on & hot water taps open.
Am I just missing something?
38,769 PostsLatest Activity: Jul 09, 2020
