Baja_Man
Dec 17, 2016Explorer
I replaced the pressure/temp reliefe valve. Drip stopped in both 12V and 120V mode!!!
Question below about water selector lever/valve....
Now, need to figure out the water fill issue. Need to verify if in fact that by turning lever pass full/vertical (where lever stops), it caused the fresh water tank to fill (while connected to city water). I'm assuming the valve is a ball valve. If so, when the ball valve is turned to one direction until it stops turning, it is fully in that mode. I don't believe water is allowed to bypass over to the other side. Is that possible?
