admiral0647
Sep 22, 2013Explorer
dbbls wrote:
You need to reestablish the water pocket in the top of the water heater. Drain the water heater tank and refill, making sure the pop off valve is not open. This leaves a small pocket of air in the top of the tank and allows for expansion of the water as it heats up.
This is correct... except it is an "air pocket" above the water level in tank. When you drain and refill the tank according to instructions, it should re-establish itself.
38,769 PostsLatest Activity: Mar 31, 2026
