wa8yxm wrote:
My 2005 Atwood developed leaks, about 100 of 'em (pin hole size) and I was able to replace JUST THE TANK.. I also replaced the 1500 watt element with a 375 watt one (1500 at 240 volts = 375 at 120) so I do not trip 30 amp park breakers as quickly .
You can just (As someone said) tape or if you have glue that does not "Eat" the stuff gule it back in place
New tank came with new insulation. new element, New mounting hardware. everythign I needed about 200 bucks as I recall but.. that memory is old.
The tank number appears to be 91028. Would you know if that is the tank you installed? Does it have the built in heat exchanger that uses the RV's cooling system to heat the water? If so, they still have the on Ebay for $200. Can you tell me what new mounting hardware it had? Does it have the black face plate that screws onto the water heater compartment? Thanks for your help.
