past-MIdirector
Jul 10, 2014Explorer
The problem is if you can do it with the right parts and safely it can be worth it. Gas valves are not only a safely device but also controls pressure. Using non stand parts can endanger you, your family and others. If you can not repair to factory spec. then replace the item for every ones safety. Saving a few dollars is not worth the cost of a hospital visit or bill from a fire department.
