revumpExplorerDec 09, 2013Water Heater ValveI have an 06 Alfa See Ya. These is a pressure relief valve on our water heater. Mine is leaking. Where can I get one and what is the model? Thanks
calamusExplorerDec 09, 2013T & PYou should be able to pick one up at any hardware store just make sure its a short one. They are not to hard to put in. Like the others said work the valve a bit if it still leaks might have to replace it.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Water Heater Check Valve
