carz57rExplorerJul 09, 2017WATER HEATER WARM WATER NOT HOTATWOOD Water heater makes water luke warm,not hot,
darsben1ExplorerJul 10, 2017then the thermostat if you hear the burner come on. IF burner does not come on either control board or gas valve
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Pump
