T_bone1Explorer IINov 05, 2014Water heaterOur used motorhome came to us with an electric\gas water heater..Problem is the electric part is a HOT ROD add on,with an extension cord that has to be plugged in around front of the kitchen cabinet....Show More
pianotunaNomad IIINov 05, 2014Hi,If the hot rod device meets your needs just run some romex and use a switch.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Tankless water heater
