Explorer1016 wrote:
Dawghouse92 wrote:
Thanks guys! I am going to check marker lights and seams tomorrow. The flooring doesnt have any soft spots and the walls feel fine except 1 spot of very corner. I assume thats where it sits until it made its way in.
If I reseal the seams do I need to get old caulk/sealant off or just seal over it?
You absolutely have to remove all of the old sealer and residue if it is to be done correctly. I have had good luck with acetone
is acetone harmful to tpo or epdm roofs? a heat gun may help get old stuff off. use dicor
