Dawghouse92's avatar
Dawghouse92
Water in Cabover!
Went to check on RV in storage today and sure enough found water in both corners of cabover. So disheartening! I looked up top and around windows but cant find leak. Felt soft on inside in corners. Dont know how long water has been getting in. What should I do... Just reseal all the seams and marker lights? If so, what do I use.
  • Get a pressure test ($100.00) from a dealer that will perform it and let you watch...JMO
  • Man that sucks! If you can get it home, I would do the pressure/soap test. Close all the windows and doors good and tight, and rig up a leaf blower in one of the windows. This puts positive pressure inside the coach. Then start with soap bubbles in a spray bottle and go around the outside and spray every possible joint, light, roof hatch, etc. Where you find bubbles, you have leaks.
    Take your time and seal each one.
    Hope the damage isn't too bad and you can dry it all out.
    Good Luck!!!
