Explorer1016
Jan 30, 2015Explorer
OK. I have the wheel ordered from Amazon.
Next question. The adhesive of the vinyl wall paper on the interior wall board has released causing the paper to wrinkle. The moisture wicked through to the interior and the luaun wall board started absorbing the water similar to a sponge. In my effort to get that interior corner dry, I pulled that section of wall paper off.This is a very heavy vinyl wall covering and I will need to replace it once I have the exterior corner sealed up. Where can I find this vinyl wall paper covering. I realize I may not be able to match it exactly but it is a neutral color without a lot of creative design in it so if I can find a similar match I hope to blend it at the inside corner and an area close to the wall opening at the slide.
I found a company that sells the interior vinyl wall board but the adhesion of the board to the insulation and framing itself is intact. the wood was only wet and not rotted so my best and easiest choice was to leave the wood alone and just remove the vinyl covering. That wall board was in the neighborhood of $165/sheet (4'x9' sheet)plus shipping. Pretty expensive, plus replacing the wood will make this a lot more difficult.
You guys have been very helpful. Again.......Thank you
Dennis
Dennis
