mikeleblanc413
Mar 01, 2014Explorer
timmac wrote:rv2go wrote:
For a temporary repair, you could just screw one of these into the inlet and turn the valve to the off position.
That's what I use as a permanent fix, my water supply hookup is inside a compartment so its not seen, works great, easy cheap fix..
THANKS to everyone who responded. I actually used a two step approach: I did as PSW described above and I also bought a similiar connection at the local hardware store and made what I hope will be a permanent fix.
38,768 PostsLatest Activity: Jan 26, 2021
