ksg5000
Mar 31, 2017Explorer II
Resealing windows in RV's isn't that hard - there are YouTubes showing the process. The window is essentially sandwiched between metal frame - the screws to the frame are located on the interior - you remove the frame/window - scrap off all the old butyl tape - apply new butyl tape - reinsert the window - trim the oosing butyl tape - and place a bead of caulk on the exterior. First time through might take you about an hour. After than you can fix the other windows pretty quick.
Hope this helps.
Hope this helps.
38,781 PostsLatest Activity: Jul 20, 2026
