Old-Biscuit
Jan 13, 2015Explorer III
2 possible sources......
Water Works 'Fill Valve' leaking thru.
OR
Pump internal check valve leaking thru.
Both will allow water into fresh water tank while on city water
Use pump....tank's full so use it And by using pump you may clean up any scale/debris on pump check valve so that is seals later when not using pump.
Fill valve on panel.......exercise it Open/Close while on city water and flush water across valve seat. Then close.
OR
38,780 PostsLatest Activity: Nov 22, 2015
