ROYBUCK's avatar
ROYBUCK
water Leak
I have a leak at the rear bed room slide, it is leaking at the right bottom corner if you are standing at the foot of the bed. I went out a few minutes ago to see if I could tell where it is coming in at as it is raining now.
There is no water on top of the slide that I can tell at the bottom corner I can feel water feel's like it is coming out where the metal piece at the bottom connects the side and the bottom of the slide a strip that goes from front to back. I cannot feel any water running down the side either.
I just got this back from a service center told them to check the seal they said it was ok, I did not take it in for the leak this occurred after.
Can't do to much now due to the rain, will get on top after it quits. thanks for all replies. Merry X-Mas Be safe Roy
1 Reply
  • If the coach is tilted a little off of level, and water does get on top of the slide, it may run under the seal and migrate to the bottom of the slide. Check to see if a slight tilt in the opposite direction corrects the problem.
