ROYBUCK
Mar 11, 2015Explorer
Water leak
This a shot in the dark. Someone would need to have a MH like mine to be able to know what I am taking about. I have a leak in the back bed room under the bottom drawer next to the closet. If you are ...
ksg5000 wrote:
You can eliminate internal water line leak by disconnecting from shore water and keep the water pump on ... if it occasionally cycles on you have a leak in the water system (outside shower, fitting etc).
If it's not a leak in the plumbing system then have the rig pressure tested - only cost about $100 or so - life short and leaks are tough to find. Just my 02.
