This a shot in the dark. Someone would need to have a MH like mine to be able to know what I am taking about. I have a leak in the back bed room under the bottom drawer next to the closet. If you are ...
The water tank is forward of the leak, in the compartment with the water pump. But the unit is winterized no water in the tank or any where else, I don't see where any water lines would run in this area, I called a dealer in Wilmington NC this morning that have a pressurized system to check for leaks, $115.00 not bad, but I am sure by the time they get through it will be more about 2 hr drive from here. Thanks to all Roy
