cableguy574ExplorerNov 06, 2018Water LeakI need to remove the right side exterior panel to get to my gray water flex pipe. It is on a 2008 National Pacifica 36A Has anyone done this
3 RepliesReplies sorted by NewestSidecarFlipExplorer IIINov 07, 2018Never remove any rear skin if not absolutely necessary. You'll be in a world of hurt. Do it from the inside or bottom.midnightsadieExplorer IINov 06, 2018drop the tank, yep might have to cut pipes to get it down, but can use repair sleeves to put back.Executive45Explorer IIINov 06, 2018If you're talking about the exterior skin, that is usually bonded, (glued) so it most likely will get destroyed trying to remove it....Dennis
Related ContentWater Heater Leak on start up.Water leakLeaking fresh water tankWater PumpFunny water pump leak
