Old-Biscuit
Jul 26, 2014Explorer III
Has is the water pressure/flow when using fresh water tank & on-board pump?
If good.....then problem is with the city water connection.....internal check valve OR with the regulator (if you use one----which you should)
38,769 PostsLatest Activity: Apr 03, 2026
