teddyu
Aug 17, 2014Explorer
Does anyone realize that a typical RV pressure regulator only works when there is flow through the line. At a static head (no flow) the RV pressure downstream of the regulator goes to the service line pressure until flow is established, then the pressure is reduced. I do not use one. My system is designed for the typical CG water pressure. When I check-in I always ask how their water pressure is. If they say high, I fill my tank and use the pump. JM2ยข...
38,769 PostsLatest Activity: Apr 03, 2026
