skipsor
Aug 17, 2014Explorer
If you are talking about the small pressure reducers that you can buy at the RV store forget about it. Those things are nearly worthless.
Do this instead. Go to Home Depot, Lowes or whoever is near you and buy the following parts:
1 Watts N45BU pressure reducing valve, Home Depot P/N 111388,
1 brass male hose to 3/4" pipe adapter, Home Depot P/N A665,
1 brass female hose with a swivel to 3/4" female pipe adapter, Home Depot P/N A661,
1 brass 3/4" close nipple, Home Depot P/N A877.
These part numbers are about 10 years old so they may have changed since then but the parts are still there. Ask someone in the plumbing department if you're not sure what you're looking for.
Put these together, attach a hose to both sides and you will not have to worry about water pressure again.
This tip appeared on here several years ago. After going through I don't know how many of the cheesy little pressure regulators, which in fact are flow reducers, I put one of these together and have never worried about water pressure since and that was almost 10 years ago.
The pressure reducing valve is the same type that is used on your home. You can adjust it for whatever is a safe pressure your particular RV.
All of the parts will cost about $50 but it beats waking up to the sound of water flowing through your RV at 3 AM.
38,769 PostsLatest Activity: Mar 31, 2026
