Loss of water pressure in MH kitchen hot water is good cold water very low. Took off line to faucet and still low pressure, then removed filter and water came out ok but not with a lot of force. Is it...
Which filter you use makes a big difference in water flow at faucets. Should be no noticeable pressure difference between hot and cold water. May have a restriction in cold water line. Remember pressure is not volume.
