RLS7201
Mar 08, 2014Explorer II
You have a Intellitec controller that controls your water pump. This has been standard on Fleetwood products for years. Not all RV manufactures use this device. There are 3 momentary switches that signal the controller. If one of the 3 switches is stuck in the closed position, it could create the problem you are encountering. Check each switch to see that it is normally open. If all the switches are open then the controller is the problem.
Intellitec Monoplex Wiring Diagram
Richard
Richard
38,769 PostsLatest Activity: Mar 30, 2026
