path1
Sep 19, 2014Explorer
mhsteve wrote:
well the pump puts out enough to go across the street ! how do you clear the lines with out hurting them ?? ................ steve
X2 on most advice above. You'll find the problem sooner or later.
Being you can shoot water across the street it sounds more like a volume problem to me, probably because of some type of partial blockage. Finding the blockage is the problem now.
Stopping in at our 1 man RV shop many moons ago, he told me of a weird one that I've thought about reading your post.
Our RV guy, after putting in a new pump, checking valves, etc... He found out that the water from fresh water tank to the water pump was not keeping up fast enough. So in the beginning it looked so obvious that the pump or valve was bad.
(I think I remember his story because of the way he found the problem)He told me he didn't have to remove any hoses to find the problem because the water hoses were the newer sort of translucent colored plastic and with a bright light could see a shadow of the water inside the line because it casted a shadow. When he turned on pump, it sucked the water line dry, then water line slowly filled up again. So the problem was really the incoming water line volume did not keep up with the pump.
Long story short it tuned out the customers kids or somebody tossed something in the water fill hole that plugged up the water line exit hole to water pump.
As far as clearing water lines, be careful and not to much air pressure. I don't go over 35 psi when winterizing. Some people put much more than 35 psi, but my limit is 35.
But if you could see that the water is not keeping up with the pump by casting a shadow on the water line with a light your problem is 1/2 way solved.
Why put any pressure to it? Might just lodge something more.
(More interesting was his way of getting the junk out of water tank.)
OK just my 2 cents, hope it helps, especially if you have the newer water lines.
