mhsteve's avatar
mhsteve
water pump help (fresh water)
i have replaced my fresh water pump as it would not pump . new pump pumps water but very slowly . no pressure . need help please .
1997 bounder
  • Make sure that your faucets are all clear of debris by unscrewing the screen at the outlet of each faucet.
    Check to see that your fill valve is in the right position for the water pump instead of shore water from a hose.
    hmmm good info & ill have to check ........ thanks .. steve
  • i changed the fresh water filter under the sink . is there more ? thank you .. steve
