moon.lake wrote:
Thanks for all your replies! This seems to be about every 5 to 10 minutes and I find it annoying,,, so I guess it time to start checking the system.
Also had the rig unplugged for a couple days and heard an occasional beep,went out to check the rig and it was both the carbon monoxide detectors,, not a full blown beeping sound, but a short occasional beep,, its not done this before when unplugged. Anything to worry about?
If it's every five to ten minutes then yes, something is wrong. Could it be one of your valves in the wrong position? In my plumbing compartment if I leave the valve that controls water from either city water or internal water in the wrong position when not hooked to city water, then my pump cycles every few seconds too. Check those first. If not that and you can't find water leaking anyplace (should be a noticeable leak with an every 5 to 10 second cycle) then it's probably just the bad pump.
