gb76087's avatar
gb76087
Water Pump Question
I installed a Shurflo 4008 pump in Oct. 2015. I've had three different occurances, when hooked to city water, that the fresh water tank has filled to overflowing while connected. In two instances the pump switch was left on. What or how does that contribute to the back flow? The other time I turned off city water, pumped from fresh tank, then went back to city water. There was no back flow for two days(until we turned the pump switch and left it on after turning the city water back on). I do have a pressure guage on water input and pressure is around 40 psi.
