I had strange problem and finally fixed. Last night all was working fine, but when I woke up, I had no water. I went crazy looking at all fuses and panel, but still no power to water pump. Finally, I ...
Only if it is bad! I would look for a bad connection on the control panel With the aid of a helper check for continuity from each switch to the panel. Test the switches with a meter.
