myface
Jan 26, 2020Explorer
Water pump
I had strange problem and finally fixed. Last night all was working fine, but when I woke up, I had no water. I went crazy looking at all fuses and panel, but still no power to water pump. Finally, I ...
dougrainer wrote:4x4van wrote:
My Itasca has 2 water pump switches, no controller. It is wired just like 3-way light switches in a house. I can turn the pump on or off, from either location. If both switches are up, the pump is on. If both switches are down, the pump is on. If they do not match (i.e. one switch is up, the other switch is down), then the pump is off.
MOST RV's do NOT use the 3 position switch like you have. They go the cheap way and use 2 position switches when they do NOT use a controller. I based my statement on the thousands of RV's I work on over 40 years. Yours is the odd ball. GOOD oddball. You would be amazed at how many RV's I have "Fixed" over the years because the Rv'er could NOT turn the pump off due to the switch method the OEM used. Doug
