TelemanExplorerOct 21, 2020Weak headlightsI have an 88 Coachmen Classic and I wonder if the is an HID headlamp option for the old sealed headlamp style. Any ideas?
JRscoobyExplorer IIOct 22, 2020First step, IMHO, would be check the voltage at the headlamp using the same ground and power path. I have found corroded connections in the wiring (often on ground side) can cause a dim lamp.
Related ContentHow to adjust LED headlights?Weak Brakesweak Cell Signal2020 F350 6.7 weak startSensitive headlight sensor
