dougrainer
Oct 10, 2019Nomad
From E trailer. Doug
I have 36’ motorhome on a Freightliner Xc chassis with air bag suspension, I am heavy on the ball, will a weight distributing hitch work? The auto adjust air suspension won’t raise the coach and I do t think the Wd would have that much in it, but would it take weight off the ball? Being a “V” nose trailer the motorcycle has to go in 1st I then back the car in to put the engine rearward of the axles, so not much load adjusting left Thanks
asked by: Mike
Expert Reply:
Yes, you can use a weight distribution system on your motorhome while towing a trailer. Since you have airbags, you will want to couple the trailer and then let the airbags adjust. Once the airbags adjust, you can then set the spring bars on the weight distribution system to take the remaining sag out of the equation.
In order to select the correct weight distribution system you will need to determine your total tongue weight (TTW) which is the loaded ready to tow tongue weight of the trailer added to any cargo stored behind the rear axle of the tow vehicle. Please keep in mind that the hitch on your motorhome will also have to be rated for use with a weight distribution system in order for this option to work for you.
I recommend taking a look at the Equal-i-zer Weight Distribution Systems. These system are one of the best on the market with integrated 4-point sway control which will work to both reduce and prevent trailer sway. I have attached the tongue weight ranges of this system for you.
asked by: Mike
Expert Reply:
38,780 PostsLatest Activity: Jul 04, 2015
