Ivylog wrote:
For a 5K trailer you do not need or want WD.
What do you base this statement on? I have towed a enclosed 2 Motorcycle Trailer behind a Denali Yukon with air suspension. The weight was around 4500 lbs total. I used a WD tow arrangement and also did not use the WD(as a test). The WD handling was far superior to NO WD. Now, behind a large motorhome, you may not feel a difference. BUT, the WD was used for SAFE towing distribution. I felt that the WD gave me more positive control on the trailer in wind and passing. I would believe the same is true behind a motorhome. Now, I do not know the particulars for WD with a motorhome air suspension. But, I have had customers using WD behind the motorhome. Doug- IvylogExplorer IIIFor a 5K trailer you do not need or want WD.
- MountainAir05Explorer IIYes, Also you should connect the trailer and load it , then run the engine to get the airbag system up , Last adjust the hitch. Remember to stay under your tongue weight.
