EdTheEdge wrote:
There is a label on the ladder that states a 250lbs weight limit. Since I weight 240lbs I fear that is too close to the limit to take chances. Your thought?
Assuming the ladder is in good shape, I would not fear to use it with care if I were you. It would be within its specifications. Like most safety critical items, the weight rating incorporates a safety factor--googling suggests it's 3 usually for ladder weight ratings, so a ladder rated for 250 pounds should support 750 pounds without failing (but one still ought to follow the official ratings, of course).
