wildmanbaker wrote:
rgatijnet1 wrote:
Disconnect the coach from shore power. Keep the ground connection for the welder as CLOSE as possible to the area to be welded.
Make sure that there are no wiring harnesses, fuel lines, propane lines, air lines, near the area to be welded.
Some people may recommend disconnecting the batteries, or ECM/TCM but I never found that necessary on any of my coaches.
X3.
Your biggest problem will be not starting a fire, or melting something. You can do the disconnecting mentioned by others to make yourself feel good, but it is not necessary. Shore power, ground is ground, do as you want. All TIG welders I have used have HF start in AC and DC. Electricity is like humans and water, it is lazy and will take the path of least resistance. Go forth and create Fusion.
X-4, I agree with the Wildman's post solid advice!
