6ofus's avatar
6ofus
Went to an RV Show Yesterday
Hello all
I have two questions for you today ??
Went to an RV show yesterday to specifically sit in and get a feel for the Sunseeker 3010ds. It’s an awesome floorplan both with the slides open and closed and would fit our family beautifully. We also came upon a Coachmen Leprechaun 319mb. Loved the outdoor kitchen set up but I wasn’t a fan of the TV on the counter. My hubby didn't mind the TV on the counter. Anyone have any experience with these models good or bad? I know they are both made by the same company but have read that Coachmen are made poorly. As a side note, we will not be buying a new model and are looking at a used unit, 2 to 3 years old.
Also, I know that generators have the ability to have an automatic start in the event the power goes out. I asked the sales guy if that was an option for the Sunseeker and he said no, they cannot add that feature while the sales guy for the Leprechaun said yes, they could add that. Are there only certain models that would have the capability of adding this feature?
Thanks for reading and any input you can give. We are still researching….one step at a time!;)
  • Hi 6ofus,
    The Jayco Seneca's I was thinking about are Class C's, sometimes known as "Super C's". The new Seneca's are really on steroids, but the older mid-2000 models were a step up from the E-450 chassis rigs. Here's an example of what I was thinking: 2006 Jayco Seneca 33SS. Here's a link to other 2006 Seneca flooplans. Just to show you what was available. Many of the rigs came with the duramax diesel instead of the 8.1L gas engine.
    I'm just mentioning these as there are some out there for a decent price and they offer the larger Class C floorplans on a chassis that can generally handle the weight.
    Jayco's are generally a fairly well respected manufacturer. Why didn't we get one when we were looking? Because Jayco didn't release the Seneca line until after we purchased our Class A, otherwise, we probably would've given one some serious consideration.
    A problem with the weight capacities you listed is that I'm guessing they include the unloaded weight on the vehicle front axle. Seeing as you really can't pack anything on the front axle, this capacity is mostly unusable, though they DO include it in the overall carrying capacity. So, those numbers you quoted are most likely 500 or so pounds OVER what you can actually load in the rig to keep the rear axle within it's limits. Meaning those numbers become 1600 lbs. and 1300 lbs., respectively. For 6 people, that isn't much at all. To make matters worse, any weight put behind the rear axle leverages weight off the front axle and adds it to the rear axle. The net effect is the front axle is usually no where near it's limit while the rear axle is near or over it's limit quite easily. There have even been posts on these forums over the years of some rigs in which the rear axle capacity was exceeded just loaded up with fuels.
    Not trying to scare you, just make sure you understand how the weight limits are spec'd and to understand that the manufacturers of these rigs (and most dealers selling them) pretty much assume buyers are clueless. This is DEFINITELY a BUYER BEWARE process.
    I am of the opinion that with careful shopping, one can be much better served buying an older, quality rig rather than a newer rig which has more bells & whistles, but not the same build quality. For example, I expect to have our rig for another 5-10 years, but when it's time for it's replacement, I'm going to be looking for a 15-20 year old, well cared for high-end diesel pusher. Basically I'll be getting a $500k+ rig for under $100k. Financing older rigs, if necessary, can be a bit more challenging, however.
    I also agree with SideCarFlip that simple is better.
    Good Luck in your search.
    ~Rick
  • SidecarFlip wrote:
    One thing I've learned (the hard way I might add) is, the more convenience and 'automatic' features any RV has, the more they break down as the acquire some age and the more it costs to get in fixed.
    My latest one (I've had 5) is simple.
    Convenience and automatic stuff is nice when new. Then it gets to be an issue.
    My exact thought when I saw the TV that lifts up and down!
  • Rick Jay wrote:
    6ofus,
    Are there really going to be 6 of you travelling? If so, most likely you will exceed the chassis weight limits for either of those rigs. If you're OK, with that, fine. Some are, some aren't. Most of my comments and suggestions below are based upon the assumption there will be 6 of you travelling, 4 of them between 1 & 18ish.
    I WOULD NOT recommend the TV over the counter as there will be times (assuming you have kids, or perhaps even your spouse) where someone will be wanting to watch the TV while meal preparation is being done.
    In my opinion, outdoor kitchens add weight and use up valuable storage space, but to each their own on that. I've just never seen the point.
    As for the generator, there are options out there. I believe there are some which you can even monitor via your smart phone, assuming you have wifi where the rig is parked. If the power goes out, it'll alert you and you can send a signal to start the generator. In fact, I'm pretty sure there are some which use the cellular network, assuming you're in an area with cell service. I'm sure there are also temperature cued remotes that can automatically kick in the generator if the temperature inside the rig gets too warm. I'm assuming you want this feature because you have pets? We travel with 2 dogs. If we're in a campground, I have the front A/C set at a lower temp than the rear, so if either A/C fails, the other will kick in. I also keep the roof vent open a bit with the fan exhausting the warm air. Not as good as A/C, but should keep the interior livable should there be a power failure.
    If there are 6 of you, you're in a similar situation we were when we started looking for our "ideal RV" back in 2002. In 2004, after exhaustively checking out just about every option starting with small hybrids to tow behind our Odyssey, we ended up with our dual sofa gas class A in our signature towing the Odyssey. We looked at just about every option in-between as well. After 14+ years and counting, and it's STILL the best floorplan we've found for the way we use our rig. Our youngest child had just turned 1 when we bought it. The class C's, like you're looking at now, did not have the weight carrying capacity I figured we'd need for our family. Before we purchased I estimated about 2,500 lbs. of food, people, pets, water & stuff, and when I roll over the scales, that's just about where we weigh in. The large, dual slide E-450 units can't handle that much weight without exceeding their chassis limits.
    If you're buying used and want a rig with that type of floorplan, I highly suggest you look at rigs a few years older like the Jayco Seneca's. They'll be pricier, but will most likely be able to safely handle the weight you need to carry.
    My best advice, though, is not to rush into anything. Buying the wrong RV can be costly as you play the "trade up" game. Do your research before you buy and get the right rig the first time.
    Good Luck,
    ~Rick
    Hi Rick
    You are correct…there are 6 of us, 4 being 18 and younger and one dog. Most times, however, there will only be 4. Two of kiddos will be with us from time to time depending on their sport schedule.
    We are mindful to the carrying capacity. The last thing we want is to put our family in danger. We did do some research on Class A’s and feel we are more comfortable with a C for many reasons. A big plus for us with the C is it’s a truck and most if not all maintenance can be done by my husband. I don’t believe that can happen with an A.
    Some people have also suggested we bring a tent for the kids. I have no problem doing this as we have dong this in the past but we want to camp in bear country. Now here is where I’m a crazy mama who worries, but I don’t want my kids in a tent with bears around….I would not sleep! :E Yes we could rent a villa or cabin as we have done in the past but we love camping and sleeping in my own bed is a wonderful feeling.
    The carrying capacity for the Sunseeker is 2100 and the Leprechaun is 1829. I admit that 1829 is a low number. We’ve camped for the past 11 years in a pop up (with no slide) and always packed light. With that being said, we are aware of the CC changing depending on how many kids we have with us. DH and I have discussed how we would handle that i.e. getting groceries when we reach our destination as we do now when we take long trips, using only as much water in the toilet to get us to our destination, packing light just to name a few. We plan on one big trip a year which would involve us getting to a destination, setting up camp and sightseeing. This is when there will be 6 of us. Other trips are local with friends for the weekend, which there will be 4. We don’t have any “toys” per se, only fishing poles and don’t plan on getting anything big. Our kids our growing, life goes fast and we want to be able to take some trips and make those memories before they are up and gone. I know we’ll get there…..:)
  • 6ofus,
    Good Luck,
    ~Rick
  • One thing I've learned (the hard way I might add) is, the more convenience and 'automatic' features any RV has, the more they break down as the acquire some age and the more it costs to get in fixed.
  • 6ofus wrote:
    kerrlakeRoo wrote:
    As to the Generator, all newer units have generators with a remote start capability, usually both on the van dash and in the coach. They are not normally set up to "automatically" start when outside power is off or it would be trying to run every time you were storing or driving it.
    So I guess my question should be, is there something out there that would give a unit this option if it did not have it to begin with? Or is there an app that would tell me if we lost power? Worried about the dog.
    I would think so, Back up home generators have an additional control that specifically monitors power and automatically starts a unit.
    I wouldn't think it should be all that different to have the same ability added to an RV, But I would start by contacting someone who installs and services the home units. They will be more familiar with this type of control and its installation.
    And remember , you will need a shut off or by-pass to allow you to disconnect and travel or store the unit. Those aren't normally concerns for the home units.
    Edit add on; For the dog concern, there are security systems which will also monitor temp, security, fire, as well as sensors for power, they will require an added internet connection for the motorhome and then would notify your phone. I have seen them discussed in here, but do not remember the name of the systems.
  • The two you mentioned aren't that different in quality, especially after a couple years use as to matter. More important is to look for maintenance and signs of heavy use, both mileage and wear. Water intrusion and the subsequent damage are the biggest concerns.
