DrewE
Feb 20, 2018Explorer III
I would be very very surprised if the battery compartment is not vented to the outside, with it being in that (quite common) location. On my Coachmen, it's very well ventilated, in as much as the "compartment" is a simple rack attached to the frame under the steps. You can see the ground around and in between the batteries.
Wet cell batteries also give off some acid fumes, though that's not the primary concern here.
38,766 PostsLatest Activity: Jan 10, 2026
