Road_Runners
May 13, 2013Explorer
Your propane could be as simple as the valve at the propane tank is closed or your propane tank is empty. Or, perhaps, if you have two tanks, the tank you have been drawing from is empty and you need to push the change over switch on the pressure regulator to the side that contains the full bottle of propane.
38,767 PostsLatest Activity: Jun 02, 2013
