Cras108er
May 13, 2013Explorer
Road Runners wrote:
Your propane could be as simple as the valve at the propane tank is closed or your propane tank is empty. Or, perhaps, if you have two tanks, the tank you have been drawing from is empty and you need to push the change over switch on the pressure regulator to the side that contains the full bottle of propane.
I love it when a plan comes together! Turns out the CO2 detector (inside the coach) was turned off. I vaguely remember the seller telling me that if it is off, then gas doesn't flow - some kind of safety feature. Thanks for your help RR.
Ready to hit the road this weekend!
38,767 PostsLatest Activity: Jun 02, 2013
