rk911
Jun 04, 2016Explorer
Tinstar wrote:
I bought a 2002 Monaco Windsor about 2 months ago. I've been getting it set up for us.
I drove it Tuesday and didn't have any problems. In fact I've not had any problems with starting the engine. This morning I went out to crank it up. I turned the ignition on and nothing. No dash, no air brake compressor running, no power to the ignition. I checked that the slides are in, brake is set, etc. I hit the auxiliary start and still nothing. I checked the battery and I have ground from the battery to the cable and I'm about to go out and check to see if I have ground to the frame. I don't know where any of the engine fuses are so I don't know where to look. I've got fuses in a LOT of bays, etc.
Any suggestions.
in addition to a coach battery disconnect switch my MH has a chassis battery disconnect switch. does yours?
38,763 PostsLatest Activity: Dec 05, 2025
