Tinstar
Jun 04, 2016Explorer
Ivylog wrote:
What did you leave on that ran down the engine batteries? Try holding the boost switch down for several minutes to see if you get some life in the gauges. If so try starting the generator so it will charge the batteries... after 15 minutes you may be able to start the engine.
14.4 volts in the engine battery. The headlight burn bright so I would think there would be enough power to light the dash lights. The shift panel doesn't light up. It's been plugged in and I've let the genset run for an hour. I held the aux. start for a while trying to get something to light up or start,,,, still nothing. I've got ground from battery to frame. I've got LOTS of power to the starter (found that when I accidentally touched the hot when checking for ground). Couldn't be a dead spot on the starter since that would not stop the rest of the electrical from working. I'm guessing a fuse somewhere. I've been looking in the book for a main fuse.
38,763 PostsLatest Activity: Dec 05, 2025
