RoyB
Sep 02, 2013Explorer III
I use MOLY BOLTS here but if it is going to be something heavier than I will put up a 3/4-inch board first with it four corners anchored with MOLY BOLTs then I can screw into the back board with regular screws... I like using the MOLY BOLTS as the screw can be removed and everything stays in place on the wall. If you are using the spring wing bolts then when you remove the screw the whole drops down behind the wall...
I have had good luck from not pulling the MOLY BOLTs thru the thin walls
Roy Ken
Roy Ken
