lafrentz
Mar 29, 2016Explorer
Automatic Transmission
When preparing to tow your vehicle, make sure the transmission fluid level is full. Do not overfill.
If Honda/Acura automobile with an automatic transmission is towed with the front or all four wheels on the ground, you must do the following every day immediately before towing:
• Start the engine.
• Press on the brake pedal. Shift the lever through all the positions (P,R,N,D,2,1).
• Shift to D, then to N. Let the engine run for at least three minutes, then turn off engine.
• Release the parking brake.
• Leave the ignition switch in ACCESSORY (1) so the steering wheel does not lock. Make sure the radio and any items plugged into the accessory power sockets are turned off so you do not run down the battery.
If you travel more than 8 hours in one day (including stopping time), you must stop and repeat the above procedures.
NOTICE:
The steering system can be damaged if the steering wheel is locked. Always leave the key in the ACCESSORY (1) position to prevent damage to the steering system when towing behind another vehicle.
CAUTION:
Severe automatic transmission damage will occur if the car is shifted from reverse to neutral and then towed with the drive wheels on the ground.
• Start the engine.
NOTICE:
CAUTION:
