Tinstar
Jul 17, 2018Explorer
Joatha wrote:
A couple of more questions:
1. When it dies, is the thermostat still on? If its on, then its not the t-stat (or less likely anyhow).
2. When it dies, does he have 120V at the AC unit? He should be able to to drop the bottom and check for voltage inside the unit.
Yes the thermostat is still on. It dies after cycling the compressor and fan several times. It's pretty random and may run several hours before it shuts down then won't come back on like it should. He may have to switch it off and on a few times and then it will come back on and soemtimes it won't OR if it just sits for an hour or so (getting hotter and hotter inside) then it will come on by itself.
I would have to ask him about 120 volts power at the unit. I told him to check all wiring at the a/c unit and check the 120 breaker in the distribution panel.
38,768 PostsLatest Activity: Dec 18, 2017
