RLS7201
Jul 22, 2014Explorer II
Seeing how you are posting in the Class A forum and have a Ford chassis, you have a F53 chassis with 4 wheel disk brakes. No adjusters. The caliper pistons move in the bore to adjust for pad wear.
Your brake system does require that you remove the calipers every two years to clean and lube the slide mechanism. While you're there, check the caliper pistons for binding in the bore. You'll also need to change the brake fluid every two years.
There has been a lot of brake complaints on the older Ford F53 (460 V8) chassis. If maintained properly, the the system works well, but requires more maintenance that most disk brake systems.
Richard
95 Bounder F53
Richard
95 Bounder F53
38,771 PostsLatest Activity: Apr 14, 2026
